Proper batteries for Diesel volvos 44MY
extraextra
Vessel Info: 1998 405, 2005 444
Postby extraextra » March 1st, 2019, 11:24 am
I have a bank of 5 batteries, plus a separate one for the generator. Want to replace all of them except the generator battery. Should they all (in the bank) be deep cycles? Boat is a '05 44 MY.
Been thanked: 413 times
Re: Proper batteries for Diesel volvos 44MY
Postby Cooler » March 1st, 2019, 2:39 pm
If standard configuration from factory, your batteries are separated into a house bank, and an engine bank ( one batt for each engine ), and a third bank for the generator. Engine (starting or cranking batteries) will give you more initial burst to your engines for starting. Deep cycle will provide longer reserve time to run house systems if you are running without battery charger support. Personal choice for how you set up, but I would do cranking batt for the engines, and deep cycle for the house. Just make sure you have good quality marine batteries. You should have separate chargers for each house & engine banks. Good luck. 8-) er
extraextra
Postby extraextra » March 1st, 2019, 3:06 pm
Thanks! The Gen battery is separate and is a start type. Going down next week and will check on what the others are.
Stay tuned!
rjr
Vessel Info: 440 MY
Has thanked: 25 times
Been thanked: 9 times
Postby rjr » March 1st, 2019, 3:25 pm
We purchased a '94 440 MY last year. Boat has two 8D batteries plus a genset battery. I was surprised it didn't have a house and engine bank.
Has thanked: 603 times
Postby bud37 » March 1st, 2019, 4:04 pm
extraextra wrote:Source of the post Thanks! The Gen battery is separate and is a start type. Going down next week and will check on what the others are.
Stay tuned!
Really, Imo you should have dedicated start batteries for your diesels......It will be interesting to see what you have there to see if all those batteries you are talking about are on one bank ( switch ) or two banks.... :beergood:
Postby Midnightsun » March 1st, 2019, 6:53 pm
Hmmm, 5 batteries sounds pretty much like my stock setup. 2 for the the port engine and bow thruster, 2 for the starboard engine and strern thruster, one for house and the generator has it's own making for 6 batteries total. I did change the house bank to consist of dual L16 6 volts giving me a 435 AH capacity which MAY change to quad L16's for a total of 870AH. :-O
That being said all the batteries are starting series 31 with the exception of the house which is deep cycle.
3dognight
Vessel Info: 2000 530 Voyager With Volvo TAMD 122P EDC 610HP
Has thanked: 15 times
Been thanked: 8 times
Postby 3dognight » March 3rd, 2019, 2:42 pm
You may want to really look around the ER for Batteries.
I have a total of 11 Batteries all over the ER
4 group 31's for my bow thruster -between engines near ft bulkhead
4 8D's for Mains, 2 per engine behind each
2 8D's mounted at the stern fr the house
and 1 31 for the Gen
Light travels faster than sound. This is why some people appear bright
until you hear them speak.........
