Volvo Penta TAMD74P-A Fault Code 3.3
golgi
Vessel Info: Carver 530 Voyager Pilothouse
Has thanked: 19 times
Been thanked: 6 times
Postby golgi » April 6th, 2019, 9:36 pm
Hi all... Prepping the boat for launch after a long layup. Port motor turned over great. Starboard gives me a 3.3 fault. Can't clear it. The motor gives a clunk when I try to crank it but that's it. Thoughts? Anyone know what a 3.3 is? It's not in the manual. Thanks in advance
Been thanked: 1310 times
Re: Volvo Penta TAMD74P-A Fault Code 3.3
Postby bud37 » April 6th, 2019, 10:54 pm
Can't help with the 3.3 fault....but considering a long layup, how are the batteries, all battery terminals clean and tight.....grounds all ok.
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 210 times
Postby pepmyster » April 7th, 2019, 8:30 am
Have to agree, find out why it's not turning over, batteries...starter....grounds....
golgi
Postby golgi » April 7th, 2019, 10:27 am
Batteries good, fully charged and load tested. All terminals cleaned and tight.
pepmyster
8.1 Volvo Penta
Fresh water boating
Postby pepmyster » April 7th, 2019, 1:21 pm
Can you turn the engine over by hand with a wrench or socket?
golgi
Postby golgi » April 7th, 2019, 8:18 pm
False alarm. Traced the the entire loom and found the coolant temp sender was not connected. It does appear I need to wire in a new connector (broken retainer clip) but all is good otherwise. Thanks for the quick responses!!
Postby bud37 » April 7th, 2019, 9:53 pm
golgi wrote:Source of the post False alarm. Traced the the entire loom and found the coolant temp sender was not connected. It does appear I need to wire in a new connector (broken retainer clip) but all is good otherwise. Thanks for the quick responses!!
So does the engine turn over and run now ? Maybe you know but if not there is a site called boat diesel that a lot of diesel guys recommend.
Postby mjk1040 » April 8th, 2019, 6:11 am
Makes you wonder why it's broke?
