Volvo QS BP1200 bow thruster replacement
- ilbacio
- Has thanked: 3 times
My Volvo QS BP1200 Bow Thruster is dead and Volvo no longer makes this thruster nor can I find a source of parts to repair it. Does anyone know if there is a suitable replacement by another manufacturer that will not require a major retrofit?
Thanks for any help on this.
- mjk1040
- Been thanked: 248 times
Re: Volvo QS BP1200 bow thruster replacement
Alaska 530 Voyager
- Has thanked: 42 times
- Been thanked: 36 times
Haven't had to retrofit one yet but even if the tunnel was the same diameter, it's likely the bolt pattern for the leg would be different so some fiberglassing there in all likelihood, and the models I've worked on utilize proprietary control boxes not used for any other brand that I'm aware of. Even if there were a brand with similar hardware, the controllers are probably outdated now anyway. Between that and different cabling, helm controllers, etc., you're basically looking at a new install save for the tunnel install from scratch.
Having said all that, "dead" is a pretty generalized statement. It could be something complicated and expensive and NLA, or it could be something simple that's readily available. Some parts may be generic that can be substituted with a part from an electronics supplier, as Mike pointed out, motors can be repaired. What component has failed and how did you reach that conclusion?
- ilbacio
- Audacia
- Vessel Info: 2008 Marquis 59
- Been thanked: 4 times
- Sgodfrey
- Vessel Info: Carver 450 Voyager
- Has thanked: 1 time
- Been thanked: 9 times
I have BP1200 but I think there is an issue in the gear box. I have not taken that apart but suspect an issue between the motor (which spins freely) and the props that turn with a little resistance. Is anyone interested in making an offer for the unit as is. I am considering posting it either as a unit or parts on eBay?
- Audacia
Please confirm (because other will want to know) 12V or 24V and year of manufacture. You may want to include a photo of the QL label on the motor housing.
