Stripped deck screws
- RWS
- Vessel Info: 1987 3607 aft
- Has thanked: 28 times
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: Stripped deck screws
- BenTen
- Vessel Info: 1984 Carver 3697 Mariner - "We'll Sea"
- Has thanked: 20 times
- Been thanked: 32 times
Ben in SC
- Renovatio
- Vessel Info: 2001 Carver 466
- Has thanked: 23 times
- Been thanked: 5 times
I know the feeling. Every thing I touch seems to be a battle. We even decided against a Silverton because the rails are secured with bolts and are not accessible ,(not the only issue but along the line of more trouble than it was worth). So we would have to DRILL access holes at every point!
Maintenance is key.
So I’ve found the same as mentioned above. Although some of the details are important.
Always spray the bolt and nut with either WD-40 (water displacement- formula 40) or a nut loosening solvent first. As not to add to the stripped issue. If the heads are stripped. First find a NEW aggressive and sharp head screwdriver (worn will not help). Automotive stores are good quality.
( not a 4-way). Often there is build up/oxidation in the head. Place the screwdriver in the head and Rapp it in place. This will give you the maximum leverage to toque the screw and loosen the bolt.
Also screw stripped removal tools are available. Often used in wood screw applications or engine applications. Remember lube the nuts. You don’t want to cause more damage and have to drill them out.
If you need more help email
Larry
- RWS
Viper wrote:Source of the post Good points Larry. When he said "stripped" I assumed he meant that the fastener is spinning. Could very well be talking about stripped heads. If that's the case and you don't get anywhere with Larry's suggestions, get a Dremel tool and cut a straight slot in the screw head, then use a standard (straight) screw driver instead of a phillips.
some screws came right out,caulked them and they went right back in good and tight and others just spin. on the ones that came out what is holding the nut?and how does one access the nut side, with out taking the interior of the boat apart?
- RWS
BenTen wrote:Source of the post I concur with Rick as I found the same thing on my 84 Carver. At first I thought they were stripped as well but once the interior was disassembled I was able to access the nut and washer.
On the ones I did get out they went back in tight, what holds the nut in place? How much interior disassembly was required?
- RWS
Viper wrote:Source of the post The guys are right, anything that is expected to handle high loads will likely be thru-bolted. The nuts are spinning when you try to remove the screw so you'll need to have a helper down below to hold the nut while you unscrew each fastener. Some applications incorporated a glassed in plate instead of using nuts. In those cases there's no need to dismantle interior areas to access and prevent nuts from moving while un-threading or securing fasteners.
Viper the glassed in plate makes sense as to how I could remove some and then tighten back up, Could the nuts in the glassed in plate have broken free and are now being allowed to turn?
- Been thanked: 1113 times
