Kohler 6.5 output issue
- ronmar
- Vessel Info: 1993 350 Aft Cabin
- Has thanked: 21 times
- Been thanked: 1111 times
Re: Kohler 6.5 output issue
If it's a main breaker issue, contact Carling directly. Carling produced a lot of breakers specifically for boat manufacturers and they'll have their own proprietary part numbers so you may not see certain parts available. If you contact them with that number, they will give you the number for the breaker that replaces it. Each number and letter on the breaker has a certain meaning. If you go to their website, it'll give you the breakdown of what each one represents.
https://www.carlingtech.com/hydraulic-magnetic-circuit-breakers
- ronmar
km1125 wrote:Source of the post do you have an automatic transfer box? Could be an issue with the relays inside there (if you have one)
No auto transfer, I have a breaker on the main panel that I think is the culprit
- ronmar
Viper wrote:Source of the post Carver uses the auto transfer relays on several models, I just can't remember what year they started do that. If you don't have any breakers or rotary switch at the main panel that you have to operate to select either "SHIP or SHORE" then you'll have the auto transfer system and the relays can fail. I would start there first.
Thanks Viper, no auto transfer there is a Carling breaker on the main panel that I believe may be the culprit. Could be the main breaker on the generator, and I know there is power to it. When I check the breaker on the main panel it shows 63 volts on the four posts. I thought that was kind of weird instead of 120 volts.
- ronmar
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Users browsing this forum: No registered users and 45 guests
