Carbon Monoxide in cabin while running generator
- tbrookshire
- Vessel Info: 2000 Santego 380
- Has thanked: 10 times
I have also had several people say that they normally run their blowers while the generator is on, but that doesn't seem necessary to me if there is no exhaust leaks in the engine room. However, I'd like to get some feedback from anyone on here that has experience with this. Thanks in advance!
2000 Santego 380
7.7 Horizon engines
7.5 kw Kohler generator
Lake Allatoona - Acworth, GA USA
- RGrew176
- Has thanked: 72 times
- Been thanked: 468 times
Re: Carbon Monoxide in cabin while running generator
2022 Stingray 182 SC
- mjk1040
- Been thanked: 245 times
- Has thanked: 597 times
- Been thanked: 1275 times
.......So consider this, any running engine consumes air from the engine compartment for combustion and exhausts it out the wet exhaust in most marine situations....this exhaust is loaded with many PPM of CO. Given the right wind direction then the gasses will be sucked back into the engine compartment thru the air intake vents for the blower system and so on.In fact Imo the blower could create that.
....but that said, you absolutely do need to run the blowers to clear any heavy gasoline fumes from the lower bilge area to be safe, especially before the engine is even started.
The hydrogen off gas from charging batteries is lighter than air and is an interference problem for electro chemical CO sensors.....there are some better ones, but in this case the alarms and numbers bring your attention to the problem and allow it to be monitored and corrected.
I believe CO to be a major problem with boats running gennys at anchor without having an awareness of wind/air movement, the genny exhaust location and their combined effects. A properly tuned genny will go a long way to help.
- Has thanked: 467 times
- Been thanked: 1759 times
Always run your blowers when you're operating the generator. It's a good safety practice and also helps remove heat from the compartment which can be a problem with some units.
- Been thanked: 1177 times
- mjk1040
The Mariner was recalled for upgrades to the engine compartment sealing.
Now maybe not a ton , but low level exposure over time can result in health problems. It is very good to have these discussions, awareness is always a positive.
- RGrew176
Good discussion to have here.
Return to “Boating & Cruising Lifesyle”
