Tranny Chatter
- Sadey
- Vessel Info: Former owner of a 2003 Carver 356 with 8.1 Mercs
Agradecida
Benedetto - Location: Racine Wisconsin/Ft. Lauderdale
- Has thanked: 4 times
- Been thanked: 29 times
Tranny Chatter
Dave & Trina
- Been thanked: 646 times
Re: Tranny Chatter
- Been thanked: 601 times
Re: Tranny Chatter
- Cooler
- Has thanked: 68 times
- Been thanked: 406 times
Re: Tranny Chatter
- Has thanked: 469 times
- Been thanked: 1765 times
Re: Tranny Chatter
tomschauer wrote:Source of the post Most likely the damper (flex plate) has a bad spring or two.
+1
Also consider that a cylinder misfire and runability issues can cause a transmission chatter too. Chatter at 1200 rpm seems a little excessive but I continue to see it all the time with seemingly no ill effects, however you can't tell until something fails or you dismantle to inspect whether the chatter is a sign of an impending failure or just normal for that particular unit. Keep an eye on the condition of the fluid. Sometimes an impact will rear it's ugly head through a transmission failure years after the running gear is repaired. For this reason, I always recommend transmission removal and dismantle after a good impact. Insurance companies don't like that as they prefer to minimize costs and just cross their fingers but it should be noted in writing that a future failure should be considered part of the original impact claim just in case that happens a couple of seasons later.
Users browsing this forum: km1125 and 24 guests
