Crusader antifreeze drains
- Helmsman
- Has thanked: 73 times
- Been thanked: 42 times
- Been thanked: 1111 times
Re: Crusader antifreeze drains
- Helmsman
km1125 wrote:There are probably more than two on the engine, but the two on the block should be located just above the oil pan flange and just behind the forward engine mounts.
Thanks. I will look for them. There are drains up higher, also, but couldn’t find those. This will help!
There are also drains on the input and output of the raw water pump and at the bottom of the oil/trans cooler (if you have the "U" shaped one), but those aren't antifreeze...just raw water.
- Helmsman
km1125 wrote:Source of the post The higher drains typically aren't on the block. They'd be in the manifolds (1 each) and in the risers (1 each).
Thanks. I have found the ones on the risers and manifolds, just wanted to completely drain the AF since I am replacing the exchanger and the oil and transmission coolers and all hoses.
Users browsing this forum: No registered users and 48 guests
