Carver 405 - Cummins 6BTA 5.9 330hp Prop Shaft Diameter
Topic author
FSP
Postby FSP » June 23rd, 2019, 1:52 pm
Looks like I'm about to be the new owner of a very nice 1998 Carver 405 with Cummins 6BTA 5.9 330hp engines. One of the survey items was that the PSS shafts seals could use replacing. I live in Canada and the boat is in La Conner WA so I can't pop over and measure the prop shaft and tube diameters. I'm hoping someone can tell me what the shaft diameter and stern tube diameter is.
Thanks,
Frank
Re: Carver 405 - Cummins 6BTA 5.9 330hp Prop Shaft Diameter
Postby Viper » June 25th, 2019, 7:02 pm
Call Carver with your hull number, they should be able to help. They can provide their part number for the assembly and the supplier. From there, the supplier should be able to provide you with the replacement seals for that unit.
