Autopilot Compass Location?
Trixboat
Vessel Info: 2005 560 Voyager
Postby Trixboat » June 28th, 2019, 11:07 pm
Can someone please tell me the compass location in our 2005 56 Voyager. I understand that it should be aft and low, perhaps on the aft bulkhead. Generator located there, so not obvious where find it. On edit, I see this should have been posted on Electronics, oh well.
TIA, Keith
2005 560 Skylounge
Volvo D12 675 HP
Re: Autopilot Compass Location?
Postby Viper » June 29th, 2019, 6:33 am
If they were all factory installed they'd all likely be in the same location but a lot of systems are installed by dealers so it can be anywhere. I've seen them in closets, inside the helm dash, cabinets, behind drawers, under births, under hinged steps, etc. Machinery spaces such as the engine compartment would be the last place I'd look as it's a good practice not to install in such areas. I wouldn't expect it to be anywhere on the bridge of a Voyager as the idea is to keep them mounted low but you never know.
What brand and vintage of electronics do you have? And are you looking for it because there's a problem or just curious?
Hopefully some larger Voyager owners will chime in. Either way, let us know the location when you do find it.
Chipita
Vessel Info: 2005 56ft. Skylounge
Postby Chipita » June 29th, 2019, 12:17 pm
Ray marine st6001 2005 vintage
Trixboat
Postby Trixboat » June 29th, 2019, 2:03 pm
Partner on the Voyager joined the conversation.
2005 560 Skylounge
Volvo D12 675 HP
Postby Viper » June 30th, 2019, 9:24 am
Start by opening cupboards and pulling drawers. I assume you know what the unit looks like? Is there a problem with it?
Postby Midnightsun » June 30th, 2019, 5:03 pm
Probably under the instruments at the upper helm. You should have a large access panel to get in there.At least this is where they put mine. ;-)
Trixboat
Postby Trixboat » July 1st, 2019, 12:26 am
Well, the compass was under the master stateroom floor. The operative word is "was." Much to our dismay, there is a foot print and four screw holes on the aft bulkhead and a bundled five wire cable on the deck. So, compass was removed. There will be a serious discussion with the mechanic who conducted the sea trial about why he didn't determine that the auto pilot couldn't hold a heading. Our bad too obviously. We are headed over to Harbor Island tomorrow, join our boat partners and then decide next steps. The compass unit is available used and new for cheap. May just buy the part and see if we can calibrate it. Or may buy new system and start abandoning portions of the ancient electronics.
2005 560 Skylounge
Volvo D12 675 HP
