buzzers and generator questions
rjr
Vessel Info: 440 MY
Has thanked: 25 times
Been thanked: 9 times
Postby rjr » July 18th, 2019, 2:09 pm
Why do boat ignitions have loud buzzers? If it's to warn me I'm about to start the engines, I know that. Can the buzzer be disconnected? If yes is it a PITA or relatively straightforward?
I have a generator issue as well. Fired up the genny and went to the control panel. Flipped the ship breaker on the house side (appliances, receptacles, etc.) and no power on the meter. Flipped the breaker on the air conditioning side and full power on the meter.
Comments welcome.
Re: buzzers and generator questions
Postby tomschauer » July 18th, 2019, 4:08 pm
The buzzers also will sound when the ignition is on and you have either high engine temperature, low oil pressure or high transmission temp. So, not a good idea to disconnect them.
Postby km1125 » July 18th, 2019, 7:23 pm
On the generator issue, it may well be the auto transfer relays that are in a box behind the panel. Another boater just went through this and had to replace one of the relays. There are a couple threads on here with pictures and part numbers.
rjr
Vessel Info: 440 MY
Postby rjr » July 18th, 2019, 8:38 pm
thanx tomschauer - had no idea re the additional functions.
thanx km1125 - will look it up.
Has thanked: 603 times
Postby bud37 » July 18th, 2019, 9:12 pm
Generally a warning buzzer on start up will sound to test the buzzer function or alert you to a fault with certain beeps.....check your engine manual for warning alerts on start up as I am not sure how the diesel set ups are...
rjr
Vessel Info: 440 MY
Postby rjr » July 18th, 2019, 9:25 pm
thanx bud37 - will do.
