1994 390CPMY diverted valve handle
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Postby tonyiiiafl » July 26th, 2019, 7:05 am
On my forward head, (as in the aft) there is a sanitation diverted valve that changes the position of waste from the tank to the overboard discharge. I was exercising mine when the plastic handle broke. It had a round hole with a squared edge to grip the stainless steel shaft. Does anyone have an old valve or the handle? I know I should replace with another, but I was hoping not to deal with this right now. Thanks!
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 15 times
Been thanked: 61 times
Re: 1994 390CPMY diverted valve handle
Postby AaHubb » July 26th, 2019, 10:12 am
Vice grip pliers
'99 404 CPMY
SeaDragon
tonyiiiafl
Postby tonyiiiafl » July 31st, 2019, 5:27 am
I also may modify a hex head wrench to make it fit too!
