New Member
- ricardiac
- Vessel Info: 1995 carver 250 express
New Member
- ricardiac
Re: New Member
Re: New Member
Let us know the engine and drive package you have, it'll help us answer questions related to those. If you have Mercruiser, the grease fitting will be on the starboard side of the transom assembly approximately half way down. If the gimbal bearing has been replaced in recent years, you won't have a grease fitting anymore as the replacements don't use them now. The fitting would have been removed and replaced with a setscrew plug.
What kind of charger do you have and have you checked if there's voltage at the unit itself? Did you check if there's any output by testing battery voltage? Is there a "Charger" or "Converter" breaker at your panel? If not, it's likely tied into one of your outlet circuits. Turn all your breakers on and see if that changes anything. If you have a hot water tank, ensure it's full of water before you turn that circuit on.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: New Member
- Has thanked: 602 times
- Been thanked: 1311 times
Re: New Member
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Re: New Member
- waybomb
- CYO Moderator
- Been thanked: 490 times
Re: New Member
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: New Member
Users browsing this forum: No registered users and 38 guests
