New antenna
thp1957
Vessel Info: 2001 Carver 356
Cummins Diesels
New antenna
Postby thp1957 » August 7th, 2019, 5:19 pm
Probably a simple answer but I’m a couple hours away from the boat and I’m trying to remember what access panels the upper station has. I need to install a new antenna and was wondering how I access the backside of the radio so I can detach the old cable and pull the new one through.
Do I lift the port side gauge panel up and reach in from there?
Re: New antenna
Postby tomschauer » August 7th, 2019, 5:35 pm
I believe your 356 is the same as my 355. Lift the seat back from in front of the helm and you should have three panels that can be removed to access everything in the helm.
thp1957
Cummins Diesels
Re: New antenna
Postby thp1957 » August 7th, 2019, 5:53 pm
Thanks. Makes sense......now.
