NEW Ray EV200 Auto Pilot Install
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Postby tonyiiiafl » August 11th, 2019, 7:25 pm
I also did the install of the new Raymarine EV200 Autopiloy. I had a vintage RayPiloy 650 that was tired. the pump was fine though. I have built in a Ray e97, and have a Ray e127 on a grunion mount. I removed the old pilot head, then made a new dash from starboard. Carefully cutting and placing. Here is is, from start to finish. I will commission it next weekend as soon as I get a longer cable for the EV sensor.
darrenlife
Been thanked: 36 times
Re: NEW Ray EV200 Auto Pilot Install
Postby darrenlife » August 12th, 2019, 7:28 am
Nice job, looks great!
tonyiiiafl
Postby tonyiiiafl » November 7th, 2019, 5:24 am
Thanks! Took a bit of ingenuity to make it look good!
Has thanked: 469 times
Been thanked: 1765 times
Postby Viper » November 7th, 2019, 7:05 am
Looking good T :down:
I see you have two terminal blocks but I suspect it's only one network, correct? If so, you should only have 2 terminator resistors. It'll work with three but you may get some weird readings or strange things happening. You should also get plugs for the ports not being used.
tonyiiiafl
Postby tonyiiiafl » November 7th, 2019, 3:18 pm
Yes, the first block was for the 2 display/gps/radar transducer network. Then a jumper to the other block. I did get plugs and capped everything off. I have to say it was an intimidating installation, but very easy. I made it harder than I truly was.
Postby Viper » November 7th, 2019, 5:43 pm
So if you have a jumper to the other block it's a single network and there should only be two terminator resistors, right? If one of the displays or peripheral has a terminator resistor on it then you should only have one resistor on one of the blocks. A network should only have one resistor at each end.
