Funky Underside of Radar Arch
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
There are four exterior lights on the arch which are utilized to light the cockpit. The surface is cracking around one of them and the others are developing blisters almost as if there is rust under the coat which in turn is contaminating the surface. I don't know if the arch is painted over metal or a fiberglassed surface.
Has anyone ever seen this? Would you have any recommendations for attacking this problem?
Thanks.
- Has thanked: 602 times
- Been thanked: 1311 times
Re: Funky Underside of Radar Arch
Find and stop the leak, pull the lights, sand and paint the affected areas and good for several more years.
- denpooch
!- Midnightsun
Suggest fixing the damage, painting and then using a decorative trim ring in order to avoid the impossible task of matching the paint. Not sure how large the diameter of the bad surface but maybe change the light for something much bigger to hide the damaged area.
- denpooch
- Been thanked: 1112 times
