Fresh Water Tanks 1992 Carver CMY 43
rgaidies
- Vessel Info: 1992 Carver CMY 43
Filled fresh water tank (S) took a good 1/2 hr to fill.
Pump and systems worked short term, until following morning.
Following morning no water being pumped through system although pump was running, taps etc spitting under pressure.
Boat had been laid up and winterized , this was the first time using on board system.
Are there drain valves for emptying water tanks for winterizing that may need to closed.
I did see water in the forward bilge so I am assuming fresh water tank (S) drained empty.
Sure hoping the tank (s) aren't busted!
Carver manual didn't shed much light on this topic.
All systems work when on shore water at marina.
Reaching out to community for advice.
- Been thanked: 654 times
Re: Fresh Water Tanks 1992 Carver CMY 43
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
PLEASE make sure your water heater is off or you will burn out the element, when not on shore water. I have had three Carvers over the years and none of them have had a drain plug in the fresh water tank, unless it was installed subsequent to purchase, which would not make sense as it is not required.
I believe you may have a leak in one of your tanks. I don't suspect that you would have a leak in your water lines because you have been on shore water. If it was a leak in you water lines you boat would fill with water.
Any leak I have had in the tank was in the area where the water line comes out of the tank and to your water pump. There is a threaded collar at this point on the outside of the tank and over time they can separate and leak.
I would put water in the tank and visually inspect the tank(s) for leaks. You need to check your tanks, lines between the two tanks, in addition to the lines that run to your water pump. Virtually everything from the check valve on your shore water line towards the pump and tanks. It will more than likely be a connection somewhere. It could also be a hole in a tank, but this is less likely. Should be easy to find.
Good luck and keep us posted.
Greg
Also check your fresh water connection while the pump is on. If the check valve fails in the regulator water will be pumped from the tank and out of the fresh water inlet connection.
- Has thanked: 602 times
- Been thanked: 1310 times
When I winterize I empty the tank and leave the tank open, there is a valve in the line also.Have a look.
- jrafaello
- Vessel Info: 1987 Carver Santa Cruz 2667 Mercruiser 260
John
- Been thanked: 1111 times
jrafaello wrote:Source of the post I have a similar question. I just bought a Santa Cruz and the seller told me it needs a new check valve for the system. He said it’s under the bed. I took the wood out and found the tank, but no check valve. There is no dock water option, is there still a check valve? Could it be the one in the pump? And I hear the pump but I have no idea where it is. Any help would be appreciated!
John
What''s your actual issue? All the pumps have a built-in check valve, or they wouldn't work. A check valve will isolate the two systems if you have shore water as well as an onboard pump. If you only have the tank and onboard pump, the check valve will hold pressure in the system, but it doesn't take much of a leak in the valve or elsewhere to make the pressure drop immediately unless you have an accumulator tank, which could hold a significant amount of pressure and allow up to a couple quarts to flow until the pressure drops off.
- jrafaello
- jrafaello
I finally found rhe valve he was talking about. Its in the bilge and it was the water filter. Thats a big difference from a check valve. Thank you everybody!
