New Inverter/House Bank
vineyardgray
Has thanked: 128 times
Been thanked: 33 times
Postby vineyardgray » September 27th, 2019, 7:04 pm
Hi everyone!
I have been busy for a few weeks on and off installing a new house bank in the 3867 Santego (just in time for winter storage :cry: )
I chose Firefly Oasis 4v 450ah L16 style batteries for the house bank. Since the boat is 12v, the 4v will produce 12v once wired in series and maintain the 450ah of each battery. These are ly 100lb a piece so I am slightly worried about creating a list - even more so considering the inverter/charger will also go on the same side.
The previous charger was faulty and wired with the wrong gauge wire so the two start/house banks were chronically under-charged and thus all the batteries onboard with exception of the generator battery are cooked.
I don't like the idea of my house loads and my start loads coming from the same batteries, and the faulty charger and fried batteries have forced my hand.
I will keep posting as I slowly make progress.
Cheers
Matt
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
Re: New Inverter/House Bank
Postby Viper » September 27th, 2019, 7:15 pm
vineyardgray wrote:Source of the post .....I don't like the idea of my house loads and my start loads coming from the same batteries,.....
I'm with you on that one. Keeping the loads isolated and on their own bank is the best way to go.
Where are you locating your inverter? I trust you're not putting it in your engine compartment unless you have an ignition proof unit.
Keep us posted on your project.
vineyardgray
Postby vineyardgray » September 27th, 2019, 8:15 pm
Here's some pics of the progress:
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
vineyardgray
Postby vineyardgray » September 27th, 2019, 8:24 pm
This is the battery disconnect and the 400a fuse:
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
vineyardgray
Postby vineyardgray » September 27th, 2019, 8:25 pm
This is the Victron battery monitor shunt:
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
Postby Viper » September 27th, 2019, 8:28 pm
Is that your house/deep cycle bank, and is that the bank that will power up your inverter? If so, what is the rated output of the inverter?
vineyardgray
Postby vineyardgray » September 27th, 2019, 8:31 pm
Here is the whole mess partially wired:
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
vineyardgray
Postby vineyardgray » September 27th, 2019, 8:34 pm
Viper wrote:Source of the post Is that your house/deep cycle bank, and is that the bank that will power up your inverter? If so, what is the rated output of the inverter?
The inverter/charger is a Victron Multiplus - 120a charge, 3000watt invert.
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
Postby bud37 » September 27th, 2019, 8:36 pm
Nice equipment....someone has been spending here I see.... :-D
vineyardgray
Postby vineyardgray » September 27th, 2019, 8:38 pm
Here's the home in which the charger/inverter will live. Fortunately, there is a lot of space in there. Unfortunately there is no bloody way I will fit in order to do the work. A two door cupboard door solution is being hatched in my minds eye:
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
