Trailer Length for 1994 Carver 280 Express
- Echo5Romeo
- Vessel Info: 1994 Carver 280 Express Mid-Cabin 7.2 Volvo Penta
7.2 Volvo Penta
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: Trailer Length for 1994 Carver 280 Express
- waybomb
- CYO Moderator
- Been thanked: 490 times
In two years you are going to buy a bigger boat anyway - get a 50' trailer and a Kenworth!
I know, I'm of no help with this one.......
- High Current
- Vessel Info: 280 Express
The late 80's carver 270, were 31 LOA and 10' beam. I do believe in the early 90's they made some boats, such as your 280, that were trailerable.
Before committing to a trailer, I would consider having a marina pull it with a travel lift to measure the boat. This would need to be done in any case to be sure the bunks or rollers are set up properly for your boat.
- Carver280_1992
- Vessel Info: Carver 280 Express
1992 - Location: Germany / Netherland Roermond
I bought a 1992 Carver 280 express with 8,5m / 2,69 m (27,8 / 8,8 feet) and with a Volvo Penta 7,4 l Motor. I want to Trailer it, but the weight control at the harbour crane shows 8.800 lbs (4.000 kg). That would be too much for a normal trailer. But I don't know the accuracy of the weight control of the crane. The catalog says only 5.900 #.
Is here somebdy who did a weight control of a simular boat?
Thanks says Ralf from Germany
- Been thanked: 1113 times
Carver280_1992 wrote:Source of the post Hi,
Hard to believe that Carver's numbers would be that far off. How full were your fuel, potable water and waste tanks when that measurement was made? If they were all full that might be 1000 lbs (roughly) right there. That's still quite a bit from what you measured though!
- Carver280_1992
there was no water (clean or waste water) in the tanks. Fuel is half full.
The catalog says only 5.900 lbs but there is no reference to the motor-type. You got this boat with mercruiser or Volvo, with smaler motor or with a big V8-block that I have in my boat. So the catalog information can not match for all typs!
- Has thanked: 603 times
- Been thanked: 1311 times
When those boats are factory weighed they are brand new, Totally dry, dry glass/coring etc.....tanks MT etc. The difference in weight between a big block and small block GM engine is around 100 #'s give or take a few.
The weigh scales on those harbor lifts are notoriously inaccurate when not calibrated regularly and used properly. Remember all is wet at this point including those slings.
The final point to consider is the fact that boats can get very much heavier over time, many can take on water in the glass/stringers/transoms/decks etc. Not counting all the gear brought on board...
Good luck with your trailer choices.......
Users browsing this forum: No registered users and 47 guests
