New member - 1996 455 CMY - Cummins 6CTA 8.3
nautohm
Vessel Info: Naut Ohm
1996 455 Cockpit Motor Yacht
Twin Cummins 6CTA 8.3 w/ ZF 301 transmissions
Postby nautohm » December 27th, 2019, 1:34 pm
Hello all,
My name is Scott Swaney. I've been boating on the Hudson River for 19 years. My prior boats were a 1997 Maxum 2100 bow rider for fun in the sun, and a 2002 Rinker 342 express cruiser that has covered from Lake Champlain to Long Island Sound many times.
My new-to-me boat is a 1996 Carver 455. Although I know a good bit about boats and boating in general, I am making the transition from gas to diesel power so I have a whole lot to learn. I look forward to hearing and sharing stories and helpful hints as I get to learn my new boat.
It's been an adventure getting her home from Boston to Catskill. One of the reasons I chose this boat was the reputation of the bullet-proof Cummins drive-train with only 700hrs. I spent a few $k on a certified marine surveyor and a diesel mechanic for a complete boat survey and dedicated power-train survey. Turns out they missed some important stuff...
2 weeks for a valve job turned into 6 weeks for a motor rebuild before I left Boston. Well, it is a boat... Kept her an easy 2000-2200 rpm the first day, eyes bouncing between the gauges and lobster pots, listening and learning the sounds of an unfamiliar boat. When I put her in neutral approaching the pumpout dock in Rhode Island, I heard a sound that I knew was not good. "Rocks in a can". No smoke, no vibrations, quiet in gear but expensive sounding in neutral. Started up early in the morning and it was much quieter after cooling down for 10 hours. Blessed with glassy water on Block Island sound and Long Island sound, I was cruising at 2200rpm doing 17kts for several hours. After 96 nautical miles the boat just turned right... no bang, no smoke, just no more transmission... So headed north to Norwalk on one motor for 2 hours, thanking the auto helm helping me minimize the zig-zag. The channel was quite narrow, but no wind=no problem.
A month later I had my new $10k transmission in the boat, ready to go boating! Forensics on the transmission said no signs of oil starvation or over-heating, likely just stress or a defect. (Shouldn't be stress with only 700hrs...) Had an uneventful trip from Norwalk to Haverstraw. The southern tip of Manhattan was a washing machine like it normally is, and wow was it so much nicer than battling through it on my old 34 express.
The next day was Haverstraw to Catskill. I had been keeping the engines below 2200rpm because the port temp guage was creeping up over 200 degrees if I went any faster than that. But when I got to Saugerties the port engine cooled right down to 180. I figured the fresh water flushed out some salt water buildup or something. So I figured a couple minutes at 2400 would be good for her.. but it topped out at 2250. No smoke, no vibration, just not enough power... Turbos. Turned off the synchronizer, it was only the starboard. Got her home to Catskill an hour later. Took the turbo apart the next weekend and it was a worn thrust washer, so time to rebuild them both.
So I took the mechanic out for a test ride after he put the turbos back on. Corrected a slight cooling oil leak then all was good. But I figured while he was there I would try to diagnose another rattling noise that I had started noticing. Uh, port transmission. Only thing I can figure is the prior owner or the broker grounded it and damaged the transmissions. It didn't show up until I put 10 hours of continuous cruising on it.
Hopefully next season I'll spend more $ on diesel than repairs on my 1996 boat with 2019 ZF transmissions.
Next I have to figure out how to work the stereo... There are speakers in the salon and the master stateroom, but I have no idea how to get the music to them. I found little volume knobs in the stateroom, but they don't do anything. I think this is a perfect application for the wireless Sonos speakers... I don't want to take everything apart to find the wires...
Happy boating everyone!
Scott Swaney
rjr
Vessel Info: 440 MY
Has thanked: 25 times
Been thanked: 9 times
Re: New member - 1996 455 CMY - Cummins 6CTA 8.3
Postby rjr » December 27th, 2019, 3:41 pm
Scott: I'm flabbergasted at your story! It's almost as if everything that could go wrong, did go wrong. Transmissions, turbos, and an engine rebuild to boot.
Next year has to be better for you. Good luck.
Postby RGrew176 » December 27th, 2019, 5:29 pm
Unfortunately a survey does not always catch everything. It's possible too that the surveyor did not miss these things as things were fine when he checked them. That's a heck of a first cruise. Hope your future cruising is less expensive.
Postby Viper » December 27th, 2019, 10:46 pm
That's some tough luck for sure Scott. You may want to do an oil analysis on the other engine! I'm surprised the diesel mechanic didn't insist on that for both engines and the trannys before rendering an opinion, it may have revealed some red flags.
Good luck with the rest of the hardware and hope you get to do some failure free boating.
Has thanked: 603 times
Postby bud37 » December 28th, 2019, 9:18 am
Welcome to the forum Scott.....wow , quite the story , especially when you consider that you tried to cover all the bases with your surveys ( mechanical and structural ). Unfortunately this sort of thing seems to be more frequent than you think. Good luck to you going forward, one thing for sure , you now have a lot more experience to draw from.
Been thanked: 491 times
Postby waybomb » December 28th, 2019, 11:23 am
Welcome aboard.
No words of wisdom can cover this. Wow.
I really do hope things go better going forward.
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 210 times
Postby pepmyster » December 28th, 2019, 8:06 pm
Welcome to the forum! Hoping that all your major troubles are now over!!!!!!!!!!!!!!!
650Guy
370 Cummins
Been thanked: 40 times
Postby 650Guy » January 6th, 2020, 7:36 pm
Scott, welcome to the forum! The good news is, you pretty much got the big stuff out of the way... at this point, your speaker project is gonna be super easy! ;-)
Best of luck with your NEW boat... its about as mechanically sound as can be now! You got this!
Been thanked: 413 times
Postby Cooler » January 6th, 2020, 8:46 pm
Welcome aboard. Sorry about all the frustration. Not fair that all happens to one boat owner. You probably have the same audio system I have, Clarion with 5 CD changer? I have 2 speaks in salon, 2 speaks in cockpit, 2 in stateroom, and 2 on bridge. The amp has a challenge feeding any more than 4 at a time. Their are probably black toggle switches located very near the salon speakers that will enable/disable those locations. The little dials are just inefficient rheostats that only really work in full on position. The real volume control is on the main unit, so you have to find the balance functions to get enough power allocated to the respective live speakers. If you push enough to get dial connected speakers, then it is too loud for the direct connect speakers. After swallowing the expense you already have, a new system will seem really reasonable and sound way better than the stock system. Happy cruising. 8-) er
Postby km1125 » January 7th, 2020, 11:47 am
Curious what really failed on the first transmission? They are pretty simple. Did gears actually break, splines shear, or the clutches just wear out?
Users browsing this forum: No registered users and 61 guests
