444 bait well pump?
- Pete
- Vessel Info: 2001 Carver 444 diesels
- Has thanked: 56 times
- Been thanked: 15 times
444 bait well pump?
Originally the surveyor said it was my waste discharge pump fitting that was corroded and now on the written survey they are calling it a bait well pump inlet.
I did not know there was a bait well. Here is what was written:
The bait well pump inlet port is significantly corroded; the pump is not operational – suggest renewing pump (Note: if there is no need for a bait well pump, suggest fitting a wash-down pump instead)
Any insight would be appreciated, I sent an email asking for clarification but wanted a second opinion. Thanks!
The best way to improve your memory is to do unforgettable things.
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Re: 444 bait well pump?
Greg
- Pete
Sorry for the confusion. The existing pump is a low-pressure pump, with outlet on the outboard side of the transom and a push-pull type switch inside the transom locker. The live bait tank is no longer there. The aft holding tank pump is still there and operational, switch is in the lazarette.
If it is a holding tank discharge pump, One end will go to the holding tank and the other to a though hull most likely above the water line.
It could also be a wash down pump.
Either way, I would chase it down, as it looks like it may be ready to cut loose.
- Pete
Users browsing this forum: Google [Bot] and 15 guests
