Replacing water heater - 2000 C530
CaptFred
Vessel Info: 2000 Carver 530 Voyager
Postby CaptFred » March 2nd, 2020, 11:53 am
My water heater is rusted out and leaking on my 2000 Carver 530, I am going to replace it. Anyone have recommendations or suggestions on how to remove the old one and get the new one in? I'm thinking I may have to remove the outer housing of the tank. I may also be able to make it fit by removing a few things, but it's still going to be one heck of a tight squeeze. Any suggestions or tips would be greatly appreciated!
Tireless
Volvo Penta D6 370 HP
Has thanked: 183 times
Been thanked: 187 times
Re: Replacing water heater - 2000 C530
Postby Tireless » March 2nd, 2020, 4:03 pm
Sounds like you are on the right path. Thats the problem when you have to remove big things from small holes.
voyagerfan
Vessel Info: 2000 Carver Voyager 530
Has thanked: 3 times
Been thanked: 8 times
Postby voyagerfan » March 19th, 2020, 10:51 pm
If you have the Cummins engines with the water heater located in front of the stbd engine, I believe it can be removed if you first remove the Halon bottle in that area, perhaps the belt cover on the front of the engine and the tool chest. You may also have to temporarily relocate the ss support rod for the salon sole. With careful measurements and a helper it just might be possible. Plan B - cut it up in place and remove piece by piece, but you will have to get the replacement back in there without using Plan B. :-)
Thanks,
John
Satisfaction
Grafton, Il
