Strange water pressure issue
- Smoken
- Vessel Info: 2000 53 Carver Voyager
- mjk1040
- Been thanked: 248 times
Re: Strange water pressure issue
That being said, sounds like somebody installed a check valve in the wrong place as what you are describing is not possible on a stock configuration unless they screwed up at the factory and the previous owner thought it was normal.
Somebody needs to follow the line from the pump to see where it is connected to the system globally and from there, follow the line to the shower.
- Has thanked: 602 times
- Been thanked: 1310 times
Smoken wrote:Source of the post We just purchased a 2000 Carver 53 Voyager. When we are connected to Marina water every faucet works great, including our shower in the master. When we use the water pump, our master shower has zero pressure, both from the faucet and if we switch to the wand. Every other faucet works perfectly. Any suggestions would be greatly appreciated.
When you say zero pressure, are you saying your shower has NO water coming out ( or a trickle ) when on the ships pump as opposed to normal when on shore / dockside water.
Could be as simple as, clean the shower fittings/screens or at least see if they are restricted. If the ships water pump is at a much lower pressure than the shore water or starting to fail then it may just not overcome the restriction.
Keep us posted.
- Smoken
