Advice on the Santego 380
- jadams159
- Vessel Info: 2002 410 Sport Sedan
- Has thanked: 6 times
I'm looking at a very nice 1997 Santego. I'm looking for any advice for things to look for. Of course a survey will be done, but I'd like to check out as much as possible on my own first. I'm mechanically inclined and have been boating for 10 years, mostly with sub 30' express cruisers with stern drives,so happy to accept any recommendations on focus areas.
The boat I'm looking at has about 650 hours on the 7.4 Crusaders. There is a small smoke from the exhaust during a cold start. It disappears within 20-30 seconds.
I can see a bit of oil/grease dripping from the shaft seals, but I assume that is expected to a certain extent. Other than that, the entire bilge is spotless.
Thanks in advance for your help!
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: Advice on the Santego 380
Good luck with the survey and sea trial. Hope it works out for you.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- jadams159
I couldn't really tell if it had a blue tinge to it or not. Blue smoke would indicate some oil burn, but if it was only at start up for under 30 seconds, would that indicate valve guide seals or rings?
- jadams159
- Has thanked: 602 times
- Been thanked: 1311 times
jadams159 wrote:Source of the post Are there any particular locations to check for soft spots?
Welcome to the forum........considering all boats have had somewhat different lives as far as maintenance and sealing practices....especially deck fittings, canvas snaps etc., all these areas can be somewhat different. I will suggest that if you want to check things out before you contract a surveyor , pick up a good moisture meter and learn how to check a boat. There is some good info online.
This will in no way be better that an accredited surveyor as they have had years of experience and will or should know where to look on the various models and boat manufacturers. I eliminated quite a few boats on our searches, but in all cases had a pro do the final, and in one case paid off big time.
Good luck with your search..
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Happy hunting.
Greg
- BenTen
- Vessel Info: 1984 Carver 3697 Mariner - "We'll Sea"
- Has thanked: 20 times
- Been thanked: 32 times
Ben in SC
- jadams159
BenTen wrote:Source of the post Welcome! Where is this Carver that you're looking at if you don't mind me asking?
Georgia
