1980 Carver 28 Voyager - Buyers advice
- Firstclass
- Has thanked: 4 times
I am new here and maybe becoming part of the Carver Yachts community.
I am 33 yo from Germany and currently very interested in buying a 1980 Carver 28 Voyager.
The boat looks a bit bulky but brings a lot of storage room for 28ft lenght, as I am planning to move partly on the water (as a 2nd home).
I am looking for some advice regarding the model and the 2 crusader 5.7 L V8 engines.
The offer I am currently interested in is this one:
https://www.ebay-kleinanzeigen.de/s-anz ... 1-211-5126
I've checked out the boat and took some pictures with which I hope to get some opinions and hints from the community. I've numbered the pics so that you could easily refere to them.
https://www.dropbox.com/sh/1dow7d54uzfk ... E3G-a?dl=0
My questions would be:
- What do you generally say about the crusaders in terms of maintenance/parts availability & costs?
- What do you think about the V transmissions?
- Should I take a look on other specific things of the Carver 28 Voyager?
It would be great to get some answers? It will be my first own boat though I have a licence for already 17 years.
Thanks a lot for your statements!
See you,
Simon
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: 1980 Carver 28 Voyager - Buyers advice
- Firstclass
The bottom paint is 2-3 years old (2017 fully renewed) and in 2019 the boat wasn't in the water.
Good to hear that you do not have a lot of doubts about the V drive. It brings a lot of room that the engines are in the aft and not in the midship ... and maybe its easier and cleaner to work on them as in a boat where engines are in the mid ship.
My alternative - a Trojan F32 looks more nice ... but it's history is not that transparent ...
- Has thanked: 602 times
- Been thanked: 1310 times
Crusader or any other engine marinizer ( the actual engines are made by either gm, ford or mopar) for 1980, it could by any of these three. The Carver is most likely ford and the trojan most likely dodge. But who knows what engine they where ordered with. If you can get the serial numbers you can find out who made the engine. The ford or dodge parts are most likely a bit harder to come by and therefore a bit more expensive, but all should be available.
Best wishes on your endeavor!
- Firstclass
Trojan F32 = 18.000 USD with 2100 hrs on two Chrysler 360s (which show leakages)
- Austinorson
- Vessel Info: 1980 3326 Voyager
1989 Chaparral 187xl - Has thanked: 10 times
- Been thanked: 2 times
I bought a 1980 3326 voyager last year. It has 270 Crusaders velvet transmissions and Walter v drives.
We like the boat, it was redone 15 + yrs ago and ni problems with the Crusaders.
- Cooler
- Been thanked: 654 times
Crusaders are great engines for sure. Don't knock the Chryslers though, they were work horses in their marine days and are still rebuilt and put into service in both marine and vintage hi performance automotive applications. The Mopar (Chrysler) 318, 360, 440 were all good engines, I've worked on a lot of them and still do. You probably won't find many parts at your typical local marina that is most likely Mercruiser driven but in most areas you can say the same for Crusader, Volvo, etc. The internet makes local access a non issue and I'd say just about every part is still available for Chryslers. On both makes for that vintage, one engine will be a counter rotator. The only thing you'd likely have a hard time finding would be a counter rotating cam if it ever had to be replaced. Having said that, a good cam shop would be able to fabricate one to original specs.
In the Carver pics, I see a few things that would raise a red flag for me and warrant inspection. There are a few but the most worrisome is whether automotive hardware was used on the engines rather than marine, or whether they are marine engines at all. The rocker covers are definitely automotive and that's what precipitated a closer look besides no paint on the intake man and what looks to be a block that is not blue. If that's the case, these engines may not be original Crusaders. While the covers aren't a concern, some other items are but I can't quite tell from the angles of the photos. Looks like the carbs are Quadrajet as I see a vacuum break, hopefully it's a marine set up with the tell tale overflow from the fuel pump, usually a small clear hose, this is critical. I don't see a tell tale line coming out of the fuel pump to the carb, again this is a must if the original mechanical pump is being used to deliver fuel. And I see what looks to be a vacuum advance on the distributor(?) If these aren't marine rated, then you have to wonder about the other items that can be potentially hazardous such as the starters and alternators or anything else in the engine bay for that matter. You don't want automotive ones in a marine gasoline engine compartment as they won't be ignition proof and can cause an explosion. Also check to see if the frost plugs on the blocks are brass. If they aren't, then they were originally automotive engines used to replace the original Crusaders.
The Walter V-Drives are pretty robust units but they fail like anything else. The good news is that parts are available for them.
Good luck with your search and keep us posted.
