Question on heat exchanger
Helmsman
Has thanked: 73 times
Been thanked: 42 times
Postby Helmsman » March 30th, 2020, 8:21 pm
Ok. The project for this spring was to replace all the hoses, and replace the heat exchanger on the starboard 2006 Crusader 6.0 engine. I was able to use my oil change pump to pull the antifreeze out as I took the hoses off and kept most of the antifreeze off the bilge. :beergood:
When I took the old heat exchanger off, though, I noticed that one of the rubber gaskets that seal the sides up had a hole torn in it. I didn’t have a leak prior to pulling. It made me a little curious. As long as the gasket seals the outer edge of the end piece, it shouldn’t be a problem for the gasket to have a hole, should it?
The heat exchanger looked in good shape, though the flow from that engine when I was winterizing in the fall seemed slow on that side. (I also replaced the raw water hoses, the oil cooler and transmission cooler earlier in the winter.)
I used the new gaskets that came with the new exchanger, and will throw away the old torn one. I am planning on having the old heat exchanger boiled out and pressure tested to ensure it is ok. If it is, I will probably keep it as a spare. The fall project will be to do the port engine. Once I have that done, I will check on here to see if anyone could use it after I have it pressure tested.
denpooch
Vessel Info: 2005 360 Mariner
Crusader 6.0 Captains Choice
Has thanked: 85 times
Been thanked: 87 times
Re: Question on heat exchanger
Postby denpooch » April 19th, 2020, 4:26 pm
Hey Nharrsion. Quick question... why are you changing the heat exchanger in the first place? Frankly, I have been 'back and forth' on whether or not to do the same on my 2005 - 6.0's. I am leaning yea, because I had a tranny oil cooler fail last season and I lost 2 weeks and 6k. Thinking "Proactive'. I have had good advice from from forum member yet am interested in your thinking. For instance, why not boil/pressure test and reinstall?
Thanks.
