No reason to have rusty Princess stove top
Sailor Jerry
Vessel Info: 1996 Carver 355
Been thanked: 8 times
Postby Sailor Jerry » April 16th, 2020, 7:55 pm
I decided I was tired of rusty stove pans on my Princess stove. The stove works perfectly, so I figured out how to remove the old pans. It's really easy. First remove the 3 heating elements. Then, there are 2 clips at the front sides. Just take a flathead screwdriver and push one clip while pulling up on the stove top. Then do the same on the other side, the stove top pulls up at the front. The pans are held on by 3 metal 'ears' that you can bend straight down and then lift the old pan out. I got exact matches from Ace Hardware for $2.99 each. They don't have the 'ears' but otherwise are exactly like to old pans, and work great.
Re: No reason to have rusty Princess stove top
Postby km1125 » April 17th, 2020, 10:28 am
Do you have the specs (manufacturer or model #) of the pans that you bought? I was able to find the inside part that drops in below the burner, but I think I found all three because they were different sizes.
Sailor Jerry
Postby Sailor Jerry » April 17th, 2020, 2:46 pm
My pans are all the same, we might have different model stoves? Here is the package:
