Water Temperature Senders
- jms642
- Vessel Info: '86 4207 ACMY
350 Crusaders
Camp Lejeune, NC - Location: Camp Lejeune, NC
- Has thanked: 13 times
350 Crusaders
Camp Lejeune, NC
- Has thanked: 602 times
- Been thanked: 1310 times
Re: Water Temperature Senders
Is one of those a sender and the other an alarm switch for each engine? Dual stations should always have dual station senders to match the gages. Don't use thread tape when installing....ground thru the block.
Did you match the numbers of the senders and switches you took out with the new ones ? Hopefully you still have the old ones.
My guess here, hard to say without seeing for me.
On each sender post where the sender wire is hooked up, in some cases there should be a small non metallic washer to prevent the sender wire from touching the grounded housing. The post is isolated from the grounded metal housing but if the washer is missing, your sender wire connector is likely shorting to ground and blowing your fuse. Check to ensure the connector on the wire is not in contact with the metal housing and let us know.
- jms642
350 Crusaders
Viper: Thanks so much. That's the ticket. These new ones (from West Marine) did not come with non-metallic washers. Clearly, this is why the fuse was blowing. I'll pick up a couple and try again.
You fellows are mighty kind to help!
350 Crusaders
Camp Lejeune, NC
