Alcohol/Electric Stove top alternative
Struggler
Postby Struggler » May 13th, 2020, 6:42 am
Here’s an alternative to fill the hole in the counter if you remove your inoperative or unused alcohol/electric stove top (‘85 Mariner). You can use a portable hot plate and stow it when it’s not being used to give you more counter space/prep area. “Custom made” :beergood: over the weekend and secured with silicon/caulk adhesive.
Re: Alcohol/Electric Stove top alternative
Postby Midnightsun » May 13th, 2020, 7:19 am
Nice! Yes, those portable induction units work extremely well and are cheap. I did something similar when I removed my alcohol/electric stove on the previous boat. I was adding ceramic to the counter top so I adjusted the opening to suit a portable unit.
Struggler
Postby Struggler » May 13th, 2020, 7:39 am
That is nice!
