Anchor rode length and how to increase
- Cliffm
"the Condo"
- Has thanked: 260 times
- Been thanked: 21 times
Now the question is, to achieve desired scope, we're limited to <30 feet for anchoring purposes. Rather than replacing with a single longer chain run, has anyone joined additional chain? or at this point do we just get 200" of 5/8 3-strand and splice it onto the end of our 120" chain?
I noted our anchor locker is not the largest so I'm thinking the rope would lay out easier? cushioning the chain fall?
can I get some yeh/ney's on this? anyone done something similar? will the factory windlass work with chain/rope?
as always, we appreciate the comments ans support.
Cliff & Beth
Renton WA
- Has thanked: 602 times
- Been thanked: 1310 times
Re: Anchor rode length and how to increase
At 30 ft deep, depending on the bottom you could be as much as 7 to 1 for rough , shifty wind conditions. All chain maybe 5 to 1.
As far as marking, I just lay the chain out and paint different colors on the chain, then write the chain colors/depth next to the windlass control.....every 20ft or so, you choose.
Can't answer about the chain splice, although I somehow doubt it.
- Cliffm
"the Condo"
bud37 wrote:Source of the post Heh Cliff....could you post the windlass make ?....you may have to contact the maker to see if the gypsy will handle both......
Thanks,
As stated, it's the "factory" installed 2006 Carver 36MY windlass, what ever make that is, hence my question for those running the "factory" installed windless running combinations of chain and rope, what are you running?
understanding that running all chain or >100' chain, running 4/1 scope works, especially sheltered.
- Danpmart
- Vessel Info: 1997 355 AC
- Has thanked: 18 times
- Been thanked: 3 times
- Cliffm
"the Condo"
I had heard of folks putting JB weld on the flats prior to assembling them. As the son of a farrier, I'm well versed at hammering things to together! I'd also considered using 3M 5200 as its next to cement to get loose!
My recent thought, was to add 150' to 200' of chain, attached to anchor, then joined to original 120' in locker via this connector.
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
I would think that the marine architects who designed your vessel limited the length of chain for a reason. (besides keeping costs down of course).
My 2005 Mariner 36 has a Maxwell 800 windless. The company (http://www.maxwellmarine.com) has a very strong technical support department and can let you know if the unit can handle combo rode.
Good luck.
You also need to consider the size of the chain locker and how that much rode will pile up in there otherwise you'll create other issues if it piles up too high and close to the windlass. There is a minimum distance that the top of the rode pile has to be away from the windlass under the deck.
- Cliffm
"the Condo"
Used 5/16 splice top combine previous 125' chain to 25' chain on the rode, 150' total chain, marked every 30', then marked the 100' 8-plait rope as well. We "blue marked" 6' from each end, anchor and chain locker to identify getting close. 250' total now.
5/15 chain splice goes through 800 Maxwell windlass without issues. We have a Davis Ind. 33lbs galvanized anchor with Mantus Swivel.
We found the best "rode" price at Dark Horse marine, really liking the extra 2 links spliced at the rode end, in order to use clevis to lock it inside locker.
- tgebler
- Vessel Info: 2000 396 AC
- Has thanked: 5 times
- Been thanked: 29 times
