What zincs for a 2001 350 Mariner?
- Dark Horse
- Vessel Info: "Dragonfly"
2001 Carver 350 Mariner
Twin 350 MAG MPI - Location: Hudson, FL
- Has thanked: 1 time
- Been thanked: 6 times
I am going to have my new to me boat bottom painted and want to replace all the zincs while I can.
The boats not here yet so I cant just go look at it to see what I need in the way of zincs.
I know I need the 2 zincs [1 1/2"] for the shafts but what others do i need and what are the sizes?
I want to have them In hand before boat gets here.
2001 350 Mariner w/ 350 Mercruisers
Home Port - Hudson, FL
- Has thanked: 602 times
- Been thanked: 1310 times
Re: What zincs for a 2001 350 Mariner?
But all this might depend on what a previous owner has installed and where they put them.
- Dark Horse
Dark Horse wrote:Source of the post Why would too.much zinc be bad
Good catch.....I should have written that differently, the info, the way I wrote it was wrong.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Boat zincs seems to have everything under one roof plus they are really well priced. Buy mine from them all the time. https://boatzincs.comMake sure you use the correct material for your application. Zinc is for salt, Aluminum for brackish and Magnesium for fresh.
Zinc in fresh is relatively useless but will last forever. Magnesium in salt will be gone in a few weeks.
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
We have lots of stray current in my marina. I put 2 zincs on each shaft, 5" on the rudder and the big block on the transom.
The shaft zincs get the most wear.
But here is a question for the crew regarding the transom zinc.
Do you get multi season use out of them? I replace each year although there is still plenty of material left. Someone told me that I can wire brush it and reuse a second season. What say you?
Also and very important...
The transom zinc is attached to the boat using a 'thru-hull' bolt. There are two sets of 'nuts' and 'washers' on the bolt; one holding the zinc to the bolt (which we always tighten) and the second holding the bolt firm against the hull. Make sure the latter nuts are tight against the transom. Those can loosen and compromise the the effectiveness of your entire grounding system.
- denpooch
I used the word 'grounding'; I believe it is actually the 'bonding' system.
denpooch wrote:Source of the post BTW....
You are now officially banned from his site, simply unacceptable.
My transom zinc was in fact zinc so after 11 years it still looked like new being in a fresh water application, same with the shaft and tab zincs. I did replace them all with Magnesium and they are definitely working now. Transom unit looks like it will last at least 5++ years along with the others.
