2001 350 mag mpi audio oil sensor part number
Dark Horse
Vessel Info: "Dragonfly"
2001 Carver 350 Mariner
Twin 350 MAG MPI
Been thanked: 6 times
Postby Dark Horse » June 11th, 2020, 7:10 pm
Hello all,
I have a 2001 350 Mag Mpi that has a bad oil pressure sensor switch. This is the switch that causes the audio alarm. Oil pressure is just fine.
I have looked everywhere and cant find a part number for it. There are like a thousand items that come up in a search even under the mercruiser name.
Any one have a part number or suggestion for the replacement?
" The trouble with trouble is it usually starts out as fun!"
2001 350 Mariner w/ 350 Mercruisers
Home Port - Hudson, FL
Re: 2001 350 mag mpi audio oil sensor part number
Postby Viper » June 11th, 2020, 8:09 pm
Post your engine serial number and I'll look it up
Dark Horse
Twin 350 MAG MPI
Postby Dark Horse » June 11th, 2020, 8:38 pm
Serial number is OL672493
Been thanked: 1310 times
Postby bud37 » June 12th, 2020, 6:26 am
Here is a link to the Mercury parts catalogue for future use......
https://www.mercurymarine.com/en/ca/par ... ts-catalog
Postby Viper » June 12th, 2020, 7:04 am
I come up with part # 87-805605A1
Dark Horse
Twin 350 MAG MPI
Postby Dark Horse » June 12th, 2020, 8:23 am
Thank you both for that info..
Helps me so much.
Dark Horse
Twin 350 MAG MPI
Postby Dark Horse » June 13th, 2020, 8:48 pm
One last question- any idea where I would find this on the engine? I've looked at the entire engine and I must be missing it.
Postby Viper » June 13th, 2020, 9:11 pm
Some are on the side of the block toward the back but most are at the back of the block behind the intake manifold. It'll probably be next to the oil sender for the gauge which is a small cylindrical canister. I believe in your case, both units will have one wire each.
Postby Viper » June 14th, 2020, 11:27 am
Your switch is likely on the back but if you see something on the side of the block, don't mistaken the knock sensor for an oil pressure switch.
Postby bud37 » June 14th, 2020, 1:15 pm
The fitting the knock sensor screws into may have a blue drain plug in it.......try not to disturb this assembly.
