Clunking in prop shaft at low RPM
Burnut
Vessel Info: 1986 carver 36 Mariner
Postby Burnut » June 29th, 2020, 6:33 pm
Has anyone experienced a loud clunking in the prop shaft at low RPM. When adding just a little power it goes away and runs great. We greased the zerk fittings and that helped a little bit but it came back.
The boat is a Carver 36 gas engines.
Re: Clunking in prop shaft at low RPM
Postby Viper » June 29th, 2020, 9:38 pm
Wonder if the prop nuts loosened off and the prop is loose.
Been thanked: 1310 times
Postby bud37 » June 30th, 2020, 8:44 am
Burnut wrote:Source of the post Has anyone experienced a loud clunking in the prop shaft at low RPM. When adding just a little power it goes away and runs great. We greased the zerk fittings and that helped a little bit but it came back.
Welcome to the forum.... Th following is me assuming you have the remote v drive set up in your boat......
Is the noise coming from the joint that is between the engine and the v drive case, or the shaft from the v drive case to the prop. Check for slop/play in the joint/ shafts.
Is there grease and residue around the area of that joint ?
Postby mjk1040 » June 30th, 2020, 8:17 pm
Rough engine idle will give you transmission noise and rattle. :beergood:
Users browsing this forum: No registered users and 40 guests
