Gas Smell
- Struggler
Gas Smell
Could it be just the gas in the carbs that I’m smelling?
I’ve let the blower run for 30 minutes or so after shutdown which I think helps a bit. I plan on idling 1 engine at a time to try and isolate which side it’s coming from. 85 Mariner with Crusader 220’s.
- Has thanked: 602 times
- Been thanked: 1310 times
Re: Gas Smell
Also most humans can smell gas fumes in very tiny amounts PPM, so it really does not have to be much of a leak.
Is this something that just started or been getting worse. Be very careful while you look for the source of this.
- vtcats
- Vessel Info: 2006 46 Voyager
Volvo D9-500’s - Location: Burlington VT
- Has thanked: 2 times
- Been thanked: 5 times
Re: Gas Smell
Struggler wrote:Source of the post I’ve searched for this topic and have some ideas based on posts that I’ve found, but wanted to throw this out here....after running, I am smelling gas. Not after fueling. I’ve looked at fuel fill lines and vent lines and don’t see visible gas/moisture. Poked around fuel lines to the carbs and don’t see much.
In my prev boat,gas powered Carver 396, I smelled gas initially after filling (course that was over 10 years from new), but it continued to get worse so even after running the boat, I could smell it. Turns out the fuel fill lines needed to be replaced. If you don’t see a leak in a tank, I would bet it’s hoses and as Bud37 said, you typically can’t actually SEE the issue in a fuel line unless bent.
Mallets Bay, VT
- Struggler
Re: Gas Smell
Re: Gas Smell
- Struggler
Re: Gas Smell
Viper wrote:Source of the post The tank lines should be checked, and have you checked the small clear line from the fuel pump to the carb? Also, pull your dipstick and smell the oil to see if it smells like fuel.
I will check that tomorrow.
Re: Gas Smell
Users browsing this forum: sbb2112 and 33 guests
