Switching Relay
ndunlop33
Been thanked: 2 times
Switching Relay
Postby ndunlop33 » July 11th, 2020, 1:39 pm
My friend has a 97 Mariner and is looking to find where to replace the generator/ shore power switching relay is located. Can anyone be of any help??? Thanks in advance!
Been thanked: 285 times
Re: Switching Relay
Postby buster53 » July 11th, 2020, 1:58 pm
My boat has it immediately behind my electric panel. Yours probably is as well. Just unscrew your panel, drop it down and you will see the switch.
Re: Switching Relay
Postby g36 » July 11th, 2020, 10:39 pm
Are you sure you have a relay to look for? May just have a ship - shore selector switch in the ac panel
ndunlop33
Re: Switching Relay
Postby ndunlop33 » July 12th, 2020, 9:04 pm
He does not have a selector switch as I do.
Been thanked: 1310 times
Re: Switching Relay
Postby bud37 » July 12th, 2020, 9:21 pm
ndunlop33 wrote:Source of the post My friend has a 97 Mariner and is looking to find where to replace the generator/ shore power switching relay is located. Can anyone be of any help??? Thanks in advance!
I believe in that Mariner the item you are looking for is attached to the back of the shore power panel....the one below the 12vdc panel......you remove the face panel then it is there or behind the aluminium box which can also be pulled out, there are some screws holding it in......just be careful and look close.
I just can't remember exactly.....the galvanic isolators are back there for sure.
