Head Vent Filter
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
Head Vent Filter
Does anyone out there ever change the head vent 'in-line' filter? Do they age and stop working?
When we flush... phew! The neighbors want to run away! Of course I treat chemically. I wonder if the filter stops working as it is 15 years old.
Also, I am getting smell from behind the refrigerator vent which is next to the galley port light which lives above the head vent. I changed out the rubber gasket around the window so I don't think the smell is from 'outside-in'.
Nothing below the salon in the holding tank area smells. The hatch providing access to the vacuum-flush area smells fine. Brian at Carver tells me there is a straight run with no joints going to vent thru hull. I am gonna pull the fridge and try to track down the source, but am scratching my head. (no pun intended!)
Any thoughts?
- mjk1040
- Been thanked: 248 times
Re: Head Vent Filter
Many boaters have made their own using just ABS pipe which can be unscrewed, dumped and refilled. Something like this would be enough to refill for several seasons. https://www.amazon.ca/Fluval-Carbon-1650-Gram-Ounce/dp/B000HHQ79Y/ref=asc_df_B000HHQ79Y/?tag=googleshopc0c-20&linkCode=df0&hvadid=335365390998&hvpos=&hvnetw=g&hvrand=11720882766667063431&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9000603&hvtargid=pla-620354807891&psc=1
- Been thanked: 654 times
- Pete
- Vessel Info: 2001 Carver 444 diesels
- Has thanked: 56 times
- Been thanked: 15 times
The best way to improve your memory is to do unforgettable things.
- Pete
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Some guy a Carver put what seems like 3M 5200 on the easy to remove threads on both of mine. Had to destroy and replace the fittings so it is now serviceable.
Should be hand tight snug or slightly snugged up with a wrench at best. Only vent air goes through this, no need to have a water tight completely sealed connection going on here.- denpooch
I can find someone with arms of rubber
