Solar panels
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Solar panels
Thanks, Andrew
darrenlife
- Vessel Info: 2002 Carver 410 Sport Sedan
- Been thanked: 36 times
Re: Solar panels
I’m not familiar with the Tesup panels but wanted to reassure you that the Sunpower panels seem good quality.
- pepmyster
8.1 Volvo Penta
Re: Solar panels
darrenlife
Re: Solar panels
- Been thanked: 654 times
Re: Solar panels
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Re: Solar panels
I purchased them from Marine Solar Innovations in my area.
Greg
- pepmyster
8.1 Volvo Penta
Re: Solar panels
darrenlife
Re: Solar panels
Tireless wrote:Source of the post I am taking delivery of 4, 110 watt Sunpower panels and the Victron 30 amp controller on Thursday. Sounds like the same supplier as Darrenlife. I am going to install them on my flybridge hardtop using elevator bolts and 3m 4200. My friends installed them like this last year and it is a great option so I don’t need to drill holes in my hardtop. Should give me 35 amps of charging power for my trip to the North Channel in August.
Greg
Tireless,
Yes, that is who I purchased from: Marine Solar Innovations.
I turned off my shore power during the install to allow my fridge to draw down the batteries so that I could test the solar charging output and was able to get 22amps which I’m quite happy with and should keep me topped up king my fridge draws around 8 amps.
I’m just getting myself familiar with this technology so forgive my questions if not applicable but noticed you are hoping to get 35A through a 30A controller, is this possible? Won’t the controller limit charging output/capacity to 30A?
I wired the panels to my main DC bus under the helm which was much easier than running the cables direct to my batteries and should minimize voltage drop with the shorter 10Ga solar wire. I also installed 40A breakers on either side of the controller. Hope this helps and appreciate feedback
- pepmyster
8.1 Volvo Penta
Re: Solar panels
- Tireless
Re: Solar panels
darrenlife wrote:Source of the post I’m just getting myself familiar with this technology so forgive my questions if not applicable but noticed you are hoping to get 35A through a 30A controller, is this possible? Won’t the controller limit charging output/capacity to 30A?
Good point, still trying to get my head around all of the techno stuff myself. I was told that is what the panels will produce, but I expect that the 30 Amp controller will maintain at the appropriate level. It is the Victron SmartSolar 100/30 MPPT Solar charge controller. The panels are 4 X 110W Sunpower E-Flex.
I was advised to put a 30 amp breaker between the panels, on the positive lead and the controller and they supply a 40 amp fuse to install before the battery. I am also going to put in an on/off switch beside the battery.
I am installing the controller in a cabinet in my aft deck, which is about 15' from the panels and then I am going to run 8 gauge wire to the switch, fuse and battery. I don't think I will loose anything. Chris is coming to my boat this evening to deliver the equipment and I will be going over the install with him as well. Fingers crossed.
If the set up does not give me what I am hoping for, then I will add two more panels and a second controller.
Greg
