Kohler 6.5 questions (MORE!)
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Postby tonyiiiafl » July 26th, 2020, 8:46 am
I was looking at my 6.5 CZ unit and saw that it looks like there were 2 25 Amp circuit breakers (1 for shore 1, 1 for shore 2)on the control pane. It looks like the previous owner put a 50 AMP breaker and placed both Leads to the same breaker. ANyone else experience this? The manual shows 2 separate breakers.
Also, when I fired my unit up from the starter replacement, it would not generate power. However, if I turned off the circuit breaker on the Genset, then started it and turned the breaker on, it would kick right in. Any insight?
LAstly, It was running a d AGAIN shit off after 1/2 hour. Coolant was full. I am thinking that perhaps some. Bad temperature sensors )Kohler part 249872?
I am going to conquer this baby one way or another!
Thanks again!
Italy
KeithS
Vessel Info: 2005 38SS
Been thanked: 23 times
Re: Kohler 6.5 questions (MORE!)
Postby KeithS » July 26th, 2020, 4:43 pm
I can't comment on your breaker situation, but normally there are 2 separate 30A breakers for the 2 shore lines.
Your difficulty in generating power on start up is either related to too low rpm, it should be set for 63Hz no load, or as these units are getting older, the capacitors sometimes have to be bumped up a little. I usually go with the 25mfd on a Carver with the auto-transfer switch for better results.
Your shut down after 1/2 hr running sounds related to overheat. Get yourself a cheapo Harbor Freight infrared gun to check it out. For $20 they are good enough for your use. The cast aluminum exhaust elbows on that model had a tendency to plug up where the water came in.
tonyiiiafl
Postby tonyiiiafl » July 26th, 2020, 7:54 pm
Thank you! I thought that the no generate issue was due to low RPM. I had probably stretched out that NLA spring which lowered th rpm’s. It sits at 110 Volts, so I should adjust up a bit to 120. I do have thee 25 MFD capacitor it or and guess I will change it out. Yes, I am also going to order the 30 AMP breakers. I Thank you! I am glad I am pointed in the right direction!
