Timer on 2807
- Davepjr
- Vessel Info: 1984 Riviera 2807
- Has thanked: 5 times
Timer on 2807
Thanks In advance
Dave
- Been thanked: 654 times
Re: Timer on 2807
Probably is connected to a breaker in your panel try water heater first since many of these in homes on water heaters. Then move to others or try and follow wiring to source or equipment.
- Davepjr
Re: Timer on 2807
Thank you ! Dave
Re: Timer on 2807
- Davepjr
Re: Timer on 2807
I just turned the breaker on for the water heater and turned the timer "past 20" as per the instructions on the faceplate...and waited a few minutes and BANG I have hot water, once again thank you for this information !
To reply to Midnight Sun's questions, this timer looks factory installed as the location of it would be next to impossible to install after so I have no idea as to why the timer, but the showers are going to feel better now !!!
Thanks Dave
Re: Timer on 2807
- Been thanked: 1111 times
Re: Timer on 2807
Midnightsun wrote:Source of the post turned the timer "past 20" as per the instructions
I think it's just a count-down timer, as when the OP wrote "turned the timer "past 20" as per the instructions" that usually how they operate.
Folks would use this so the water heater shuts off after a certain amount of time so it isn't left on inadvertently. I almost always shut off the breaker for the water heater whenever I leave the boat. You would have to make a point to anticipate when you need hot water so you give the heater plenty of time to get the tank up to temperature, or keep resetting it as the day goes by.
Re: Timer on 2807
Personally I would remove the timer and manage its operation with the panel breaker, it's safer that way. It can't be that difficult to remove as it seems accessible given that you were able to set it "past 20" That would be a pain to have to reset for varying needs.
So out of curiosity, how does this work? You set the timer for a certain length of time and then it shuts the power off to the heater after that, and you have to reset every time you want hot water, or want it at a different time? And as Hans mentioned, how does it know what time it is if you keep disconnecting shore power, you have to reset the current real time when back at a dock? Am I missing something here?
Not calling you out Dave, I'm just trying to figure out what the real benefit is and why someone would install one. From the theories so far, I don't see it but hey, I've seen a lot of other things that made me scratch my head before too.
Glad you found the problem
Re: Timer on 2807
- Davepjr
Re: Timer on 2807
