waste gate lines 396 Carver MY
- winedown
- Vessel Info: 2004 396 Carver motor yacht
- Has thanked: 17 times
- Been thanked: 3 times
Re: waste gate lines 396 Carver MY
- winedown
- Hugo
- Has thanked: 2 times
- Been thanked: 23 times
Volvo has a spec of how much the valve should move for a specific amount of air pressure. A little brake parts cleaner and some compressed air fixes the problem. Have them put a little high temp anti-seize on the stem of the valve and it won't seize again, last I touched mine was 5 years ago. It's a simple job with a 3 bolts and a gasket.
The hard air line between the turbo and the waste gate sometimes brakes so keep an eye on that.
If you don't have boost gauges you may want to invest in that so you can see when the waste gates aren't working. The turbos on these motors are over sized and with the waste gate sticking you'll be pushing more boost into the motor than it was designed for.
Good luck!
