They both stay sync'd up to about 2800 RPM's. When I bring them both beyond that the Starboard will drop a few hundred RPM's then bounce back up, then drop down, then up, etc... It seems to drop back to around 2800. I got them both @ WOT doing almost 26 kn. Up to 2800 RPM's doing 15kn they both run fine.
A friend of mine said he had the same issue and his turned out to be the Turbo Charger.
Anyone know a way to test/prove it is the Turbo?
Anyone have a better/cheaper remedy than changing (about $4500/engine) out the Turbo?
Thanks,
