New Owner 86 Mariner 3297
- rstarr813
- Vessel Info: 86 Carver Mariner 3297
- Has thanked: 2 times
I know the sofa and dinette cushions are not perfect....does anyone know the dimensions for the sofa so I can get a new one?
Also, for boat lettering/decal....What is the dimensions on the transom?? How would I remove old boat name???
I haven't picked up boat yet...it's inCleveland, and I'm in Chicago...going to haul it out next week....
- waybomb
- CYO Moderator
- Been thanked: 490 times
Re: New Owner 86 Mariner 3297
I can't help with your questions though.
- Has thanked: 602 times
- Been thanked: 1310 times
- MrMainer86
- Vessel Info: 1986 Carver Mainer yacht two 305 v8's
- Gag_Halfront
- Vessel Info: 1990 Carver Mariner 3297
- Been thanked: 20 times
Congratulations on your new boat. I hope everything goes well!
- Been thanked: 1111 times
rstarr813 wrote:Source of the post
Depends if they are paint or stickers. If paint, you might be able to wipe them down with Acetone or Carb Cleaner and take the majority off quickly. Might need to use something like a Scotchbrite pad with it. If that works, then use some rubbing and polishing compounds to shine it back up. If you need something more aggressive, you can use some 2000 grit sandpaper on the paint, then do the rubbing/polishing after.
If it's stickers, you might be able to use heat to soften them and pull them off. This works 50% of the time...just depends on the glue that was used. 3M also makes a drill bit attachment that works wonder like a big eraser to take them off (works great with old stripes too!!)
MrMainer86 wrote:Hello, I just bought a Carver Mariner 1986 with the two 305's I am looking for original parts if any one knows anyone who has some. Mostly fly bridge controls and seats.
There was a guy not too far from here that was parting out a mid-80's 3207. Probably had a lot of the same parts. I'll see if I can find any of his contact info and fwd if I can.
