Trim Tab reservoir
SunsetSteve
Vessel Info: 83 Carver Riviera 28
76 Albin 25 (outgoing)
Has thanked: 30 times
Been thanked: 19 times
Trim Tab reservoir
Postby SunsetSteve » October 12th, 2020, 3:30 pm
Riviera 2807 - supposed to check and change the trim tab pump reservoir (pic below), but there does no appear tp be any access to perform that. What am I missing (again)? I also asked on the FB Group but the photo would not stick.
:approve:
Been thanked: 1310 times
Re: Trim Tab reservoir
Postby bud37 » October 12th, 2020, 3:47 pm
Take that plastic lid off and then look at the front left if I remember right for the filler tube/cap.
It looks pretty clean down there, new water pump etc.
SunsetSteve
Postby SunsetSteve » October 12th, 2020, 4:10 pm
Yep, I am totally impressed with how fresh and new everything looks in the water management dept on this boat. No wonder the surveyor was so positive - actually almost gushed! LOL
Thanks Bud 37! Going right back out there to follow up. :approve:
Been thanked: 413 times
Postby Cooler » October 12th, 2020, 4:50 pm
You will need something that is narrow. The filling tube is tiny. That screw at the top is what you need to remove to get the cover off. First off, shine a light on the translucent tank at the bottom of the unit. They normally do not require adding fluid very often. 8-) er
Postby Midnightsun » October 12th, 2020, 5:03 pm
SunsetSteve
Postby SunsetSteve » October 12th, 2020, 5:08 pm
removed the cap - explored with a screwdriver down the hole and it seems blocked. Can I be confident that the oil will travel into the reservoir? I hope so because it looks empty to me. I can't see a line indicating the level.
Also - the oil container has a narrow fill thing just like the ketchup bottle above, but of course I cut a little lower than I should have. Now need to find a tiny funnel!
Postby Midnightsun » October 12th, 2020, 5:11 pm
There is no line for max or min level. If memory serve me right it should be 1" from the top when trim tabs are fully up. FYI, trim tabs do not consume oil therefor if the level drops or the tank is empty there is a leak the needs to be attended to. ;-)
Been thanked: 1111 times
Postby km1125 » October 12th, 2020, 5:22 pm
IIRC, that whole trim pump assembly slides down into its mounting bracket. If there's enough slack in the hoses and wire harness, you can slide it up and just look inside the bottom reservoir section
Funny side note... on my very first boat, nearly 40 years ago, I saw those plastic lines and thought somebody cheaped out when they did the installation. Replaced it all with copper. Years later when I learned more, replaced it back with the OEM plastic lines.
Postby Cooler » October 13th, 2020, 2:11 pm
Hans - not laughing, but I am going to go to get one of those ketchup bottles! That would be perfect for a couple of hard to reach parts. Great idea! 8-) er
rcoff512
Vessel Info: 1999 Carver Voyager 450
Home Port, Long Island NY USA
Has thanked: 12 times
Been thanked: 8 times
Postby rcoff512 » October 16th, 2020, 10:40 am
