CO2 in the Cabin
- TheNatalina
- Vessel Info: 1984 Carver Voyager 28 Cabin Cruiser
- Been thanked: 2 times
CO2 in the Cabin
I am a novice boater, so don't take my level of boat knowledge for granted. Fire away with any comments and suggestions. Thanks!
- waybomb
- CYO Moderator
- Been thanked: 490 times
Re: CO2 in the Cabin
- TheNatalina
- TheNatalina
The detector is a purchased Unit for the cabin that is also battery operated and seems to check out fine - again, operating normally in that it only sets off while cruising and then returning to 'no alarm' and normal readings ('no Carbon Monoxide present') once the engines are shut down.
Any thoughts on a good way to check for an exhaust issue? I am not seeing any smoke with the engines operating at cruise and removed the aft deck hatches in the slip and restarted the engines and am not seeing anything.
I even washed down the Bilge and Engine Bay thinking it could have been residual, but no luck.
Thanks for any input.
- chpsk8
- Has thanked: 27 times
- Been thanked: 76 times
1. Is your layout the galley to aft? So the fridge space you are talking about is close to the engine compartment?
2. Where is the CO detector located?
3. If you crack a hatch or window while underway does that help?
4. If your detector is battery powered, can you move it closer or further away from the galley and see if it takes longer to alarm? Can you use it to narrow down where the problem is coming from?
CO is no joke so use some caution. Common causes are the stationwagon effect when running. If that sliding door isn't tight, it's could get through there.
Calling Carver could answer your question about the bilges being connected. They would know what the original design was and are amazingly helpful at sharing build specs.
something to try, crack the front (bow) hatch just a bit and turn off the blowers at cruising speed. (you don't need to run them at cruise speed) this will give you a small amount of positive pressure in the cabin and should stop the alarm unless you do have an exhaust leak.
- TheNatalina
I can reposition the Detector and try it in several locations and will also look at the seals on the aft deck door and give the slightly open hatch suggestion a try.
These are excellent ideas and I really appreciate all the help and suggestions. A call to Carver may also answer the question about the open space under the refrigerator. It doesn't seem like it should be open, but it also does not appear to be cut out or rigged in any way.
I'll follow up with a report after some further analysis. Thanks again!
- Has thanked: 602 times
- Been thanked: 1310 times
Now in the operators manual there may be an explanation of how to deal with such an event in your boat.
- WishGranted2020
- Vessel Info: 1988. 38’ Santego -3867
- Has thanked: 1 time
I too have this problem (and appears only while cruising) I have a 38’ With the galley more midship portside. I use two Battery powered CO detectors one at the galley and another repositioned in different spots to try to detect which detects faster (also a second also eliminated the variable that it’s a problem with the first detector). It freaks out my adult kids that this is even a thing (we just made the move to power from sailing forever - so lots of new things learned). I haven’t found the source either. However, thank you to the many Useful suggestions from other contributors.
