Fuel issues
- Smoken
- Vessel Info: 2000 53 Carver Voyager
Fuel issues
We cannot seem to fix fuel issues created by the lack of use. We have fungus in our tanks and have tried many things to try and fix including fuel polishing , bio cide fuel additive, over 550 gallons of new diesel and we change the racor filters every eight hours.
Is there anyone who can give us guidance on what we need to do next?
- Been thanked: 1113 times
Re: Fuel issues
The best way to clean the tanks is having a high-volume high-pressure pump with a couple filters ahead of it. You need access to the top of the tank to remove something like a fuel sensor so you can stick two copper tubes in there... one to the bottom of the tank and the other than you can move around. In-tank baffles can make this harder to do. The flow comes from the one you stick down to the bottom, and the other one you move around as much as you can to stir up whatever is remaining in the tank. Also helps to pinch off the end of that one so that the returning fuel is spraying out (like a hose sprayer). The less fuel in the tank the higher the ratio is in junk/fuel. If your tanks are low enough, you can pump everything out of one tank into another so once you get the tank clean you fill it only with clean fuel.
The other thing you can do is make modifications to your fuel filtering process to make it easier to switch to a backup so once a filter is clogged, it's an easy process and doesn't delay your boating. You put in a dual two-way valve and wire before and after two filters so it's an easy toggle to the backup filter. You can also put in a meter to measure suction in the line so you can see when the filter is getting clogged before it affects engine performance.
- Smoken
Re: Fuel issues
- RobGunn
- Vessel Info: 1990 Carver 3607 Aft Cabin
"FINALLY" - Location: St. Joe MI
- Been thanked: 23 times
Re: Fuel issues
- Hugo
- Has thanked: 2 times
Re: Fuel issues
https://www.sbmar.com/articles/marine-f ... board-way/
Users browsing this forum: No registered users and 7 guests
