Carever 26 - Fuel tank original set-up?
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
The fuel tank is a 111 gallons 'skyline industries; model 46870-00' aluminium tank. In my boat this one is filled with diesel fuel. Unfortunately, some doofus seems to have spilled diesel fuel along the side (I suspect when trying to take out the fuel level meter, which requires removal of a fuel line) so the boat stinks.
Recor filters fitted with the transparent bottoms, pretty messy so that's to be cleaned soon. These may be originally there when the petrol engines were fitted?
Is this the original tank? is there a bilge pump underneath? Is there a way to access the space under the tank (perhaps through the engine bay? there is water tank mounted in front (full at the moment, working on that) so can't see the bulkhead untill it is removed).
If there is no connection between engine bay and petrol-tank-area-bilge, would it be an idea to drill a hole to be able to flush that bilge?
All thoughts welcome.
- Phrancus
- Contact:
Re: Carever 26 - Fuel tank original set-up?
I don't have much detail of the boat lay-out as it was originally, so I'm sometimes struggling to understand why something is fitted the way it is. Some things I can trace back to the switch from petrol to diesel and some things were done when 'europeanizing' the boat (different shore voltage). Even some things changed when the boat left Belgium and came to The Netherlands (different sockets). Left are some odd bits and things that were bodged-in in later years.
- Been thanked: 1111 times
Phrancus wrote:Source of the post ....
Recor filters fitted with the transparent bottoms, pretty messy so that's to be cleaned soon. These may be originally there when the petrol engines were fitted? ...
I can't address any of your questions on accessing the area below the tanks, but those filters with the transparent bowls would likely NOT have been original equipment with petrol engines. In the USA, those would be prohibited on a petrol engine so Carver would not have installed them.
