[26 command / 280] Request: picture of your panel
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
Mine has a creative mess and as I'll have to rebuild the thing anyway, perhaps I can do that in style.
edit: I was initially looking for the fuse/switch panel but am also interesed in the 'dashboard' (dials around the wheel) edit II: 'helmpanel' as I found some remnants of a previous engine setup.
Thanks in advance
- Been thanked: 1111 times
Re: [26 command / 280] Request: picture of your panel
Here's a couple I snapped off youtube. I've used that for a lot of ideas on other boats. When searching for your boat, you can also add "sedan bridge" as folks might not be as familiar with the term "command bridge". There are several videos on the 26 and 28.
- Phrancus
- Contact:
The left part I see a radio fitted where in mine there is a DIN space in the board onto which the rocker/fuse panels are mounted. Well, were supposed to be, didn't fit quite right so someone made it half-fit...
