What do you use the water for?
- SunsetSteve
- Vessel Info: 83 Carver Riviera 28
76 Albin 25 (outgoing) - Location: Gananoque
- Has thanked: 30 times
- Been thanked: 19 times
My questions:
1. what do you use the water for? I am thinking - washing up, showers, cooking . . . but drinking? Is dockside water supply and 40 year old holding tanks/tubing to be trusted for drinking unboiled water? (not by my wife, no way, whatever your answer might be lol) Or do you bring a few jugs aboard strictly for drinking? What is normal?
2. What sore of range to expect with conservative speeds with this sort of gas storage? Twin 220s btw.
Just wondering what to expect when we finally launch in the spring.
- Has thanked: 602 times
- Been thanked: 1310 times
Re: What do you use the water for?
Here is a GPH calculator, just plug in your stuff and it will be close. Hull speed for you will be no more that 6 knots ( approx 1500 to 1600 rpm) and on plane cruise probably around 2800 to 3100 Rpm from what I remember ( had a boat with the exact same hull as yours). Just calculate your range based on the numbers you come up with.
https://www.boat-fuel-economy.com/fuel- ... calculator
We always have bottled water for drinking.
Your twin gas Carver will be a bit of a "shock" with the fuel burn, but you will get from A to B in less than 1/3 time if you desire.
- Been thanked: 1111 times
At the dock we are usually connected directly to city water, so the potable tank is used only away from port.
You will go through a lot more fuel with gas than the old diesel, but you will now have the option to get on plane and get places faster if you wish.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- SunsetSteve
The living space and features on this boat far exceed that of my old Albin 25 diesel, and we are excited to begin enjoying her in the spring. Just now the Riviera is in my yard waiting for the shrink wrapper and a decision on a new name ("Open Water" doesn't have the excitement/adventure level that I want!).
- Cooler
- Cooler
- SunsetSteve
I will try calling Carver but just in case, HIN is CDR800039182-83
Users browsing this forum: Google [Bot] and 19 guests
