Sealant around the exhaust
- 650Guy
- Captain
- Been thanked: 40 times
Boats all tucked away and after my lift out hull inspection, I noticed that the exhaust pipes coming out the hull have sealant around them. Just a very small bead, but its a small bead of black sealant. Do you know what type of sealant would be best to use there to re-seal it. Mine is pulling away a little bit and want to get it all sealed up again.
Oh, I have a 2003 396 with Cummins 370B’s installed.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: Sealant around the exhaust
- 650Guy
- Captain
If you think there is a problem, you should loosen the thru hull outlet clean all the 5200, reapply and reseat.
