TAMD74EDC start up issue
- the Office III
- Vessel Info: 2000 Trojan/Carver 440 Express w/ Volvo TAMD74EDC ZF tansmission
600 hrs. - Location: Denton, Texas
I’m jumping on this site because I’m sure one of the Carver owners on here may have had this issue come up. I have the TAMD74EDC set up w/ ZF transmission. About 600 hours.
I just Had my boat pulled to have a bottom job, shaft log seals replaced, all rubber below the water line, Props refurbish. Oil change, Trans serviced.. And now my Starboard engine isn’t cooperating..Very frustrating...
Port engine everything works perfect. Everything worked perfect with both motors/trans before pulling the boat out for the services.
Problem…
Starboard engine — When doing the sequence to start the boat it will not turn over. First, push the active station button and Neutral light comes on. Turn ignition and nothing but A Relay behind the dash starts clicking and it’s never done that before (Switched relay with another one, still did the same thing). And NO error/diagnostic blinking light While all of this is going on. I can then Manipulate starting the engine by pushing diagnostic button. After It turns over and starts, but not normal. It runs almost 200 rpm higher than normal. ( Normal is about 700 it running 900.) It will not shift into gear. It seems like it’s in a fail safe mode. I’ve read through all the trouble shooting booklets on the boat there’s not a scenario for this problem.
I’ve swapped all relays from other motor to eliminate that. Nothing changed..
Any help is appreciated. I’ve tried to think outside the box on this. It does have ZF transmissions. Is it possible when they pulled the shafts and did the oil service could something got out of sink where its not reading neutral or it out of gear?
Thanks,
Jon
- Has thanked: 602 times
- Been thanked: 1311 times
Re: TAMD74EDC start up issue
the Office III wrote:Source of the post Any help is appreciated. I’ve tried to think outside the box on this. It does have ZF transmissions. Is it possible when they pulled the shafts and did the oil service could something got out of sink where its not reading neutral or it out of gear?
Welcome to the forum.....I kinda agree with you here.....if all was well before the service, it is highly probable someone stepped on something, cracked a hose, loosened a ground, misaligned a wiring connector etc......good luck man, it is unfortunate at the very least.
- Been thanked: 1113 times
- Carpediem
- Vessel Info: In process of buying 2000 506 with Volvo TAMD 74s
- Has thanked: 2 times
- Been thanked: 25 times
Rusty Mayes
- Carpediem
I disconnected every cable plug in harness at the engine and under the helm, cleaned with electrical contact cleaner, applied some dielectric lube and reconnected. I cleared to code and started the engine normally. I really did not see a particularly suspect connection so no idea which one was the problem but its fixed regardless. It is curious that three wires on each of the engine plugs are hard wired around the plug.
Hope you found your issue
Rusty
- Tbw5959
- Vessel Info: 2004 466 M/V Salt and Light
Volvo TAMD75's & Kohler 20kW generator - Location: New Bern, NC
- Has thanked: 39 times
- Been thanked: 4 times
As I understand it, they had troubles with idling engines - get this - autonomously shifting into forward gear - and determined that any kind of weakness in the connection on those 3 lines was the culprit -- hence the recall campaign.
